Water Pump Info
Old Mar 23, 2023 | 06:27 PM
woodranch's Avatar
woodranch
Default Water Pump Info
Unfortunately ,my 2018 GTS has the water pump issue. I am taking it to the dealer tomorrow. For those of you that have already taken care of it, is there anything I should be aware of that the dealer does fix or go over. I vaguely remember some members mentioning earlier that some parts that were replaced, were still defective. If there is anyone that would be kind enough to post a copy of the repair bill that repaired this issue correctly or used the most updated parts, I would be most appreciative!
Just really do not want to deal with this again.
Old Mar 23, 2023 | 07:10 PM
polobai's Avatar
polobai
They should also replace the valve block for vacuum when they do the pump.
Old Mar 23, 2023 | 08:15 PM
woodranch's Avatar
woodranch
Thank you polabai!
If anyone else can think of anything else , please let me know. Many if you have already experienced this and are way more knowledgeable then I. Thanks 🙏 again!
Old Mar 23, 2023 | 09:03 PM
barncobob's Avatar
barncobob
heres what they replaced on my 17
antifreeze
valve block
o ring
oring
hexagon nut
coolant pump
vacuum pump
gasket
control line
Old Mar 24, 2023 | 03:48 PM
vanlieremead's Avatar
vanlieremead
here you go
