Oil Changes- Why does Porsche Recommend Replacing Oil Drain Plugs?
Found this one ($4.98) when ordering the oil filter for my 991.2 from rock auto. Installed recently, no problems so far. Now wondering if I should try to reuse it. It looks just like the oem plastic ones I have been using for years. It wasn't letting me copy or snip it into the page so I put it on a word doc and attached that. Made by URO parts, part number 06L103801PRM.
HD Brass Upgrade, ACM Synthetic Rubber O-Ring; Includes O-Ring
Simple guys, weight. The plastic plug is turned until it notched closed. 1/4 turn.
devtec (03-21-2023)
I ordered the same thing and am waiting to use on my next oil change. Any idea where to get replacement O-rings?
Yes, I have a 991.1. Sounds crazy though that Porsche went to a plastic oil pan drain plug . Perhaps , there was a trend of the aluminum drain plugs "fusing" themselves to the similar metal aluminum oil pan ? Plastic would not have this issue and understandably they would be disposable.
Former Vendor
I had never seen a plastic plug before when we got our 991.2 so I got spares, but never used them. Maybe we are just careful, but I compared the o-ring seal and plug to a new one at each oil change and could see no difference even with mild magnification.
I get why they want you to replace it, because there are a lot of ham-fisted techs out there, best to be safe than sorry, and it's a part that can be easily damaged. Not that I'd recommend not replacing it, but we never saw a need and it was never an issue.
“One of the biggest chunks came from a new plastic oil sump that saved 4.4 pounds. The sump is comprehensively baffled to ensure a supply of oil near the pickup of the oil pump no matter how aggressively you’re driving, but the idea of an oil pan molded from even the most modern polymers doesn’t inspire confidence among those who expect robustness from their Porsches. To prove the pan’s durability, the engineers tested it by dropping an engine onto a concrete floor from a height of 39 inches. Thomas Brandl, one of those engineers, said the pan developed no leaks.”
https://www.caranddriver.com/feature...-911-carreras/
If you are using the correct 8mm hex bit and torque it to spec (or less), why would they fail? I still have the original that has gone through at least 7 oil changes and it still looks like new.
See the videos below for the answer, a plug is only ~ $5 - just replace it:
https://youtu.be/26Sz9t6LeIo
https://youtu.be/4mXowy0SDhA
And in that second video, reminds me of when I went over to change the oil on a friend's 997 and the 8mm bit would not go in more than an 1/8 inch. Another "aftermarket" drain plug. I wish some people would take up basket weaving whoever did the last oil change.
Luckily I was able to remove it with a flat blade screwdriver and hammer with no damage or gouges to the oil pan. You can see the cut. No big deal, he had two new "aftermarket" drain plugs which did not screw into the oil pan. So I went home and got my new "Porsche" spare drain plug with the M18 x 1.5 thread....amazingly the factory one fit.
Agree- I have been changing oil in my own cars since 1978 and have never needed to replace an oil pan drain plug. The right tool ,and torque wrench , is necessary.
I am not sure whether it is a Porsche recommendation, but it is posted on several places and on YouTube videos on DIY oil changes for the 911.
I can only speculate that since the drain plug and the oil pan on the 991.1 are aluminum (?) that similar metals may "weld" together if over torqued.
The plastic drain plugs on the later models make sense to replace.
At any rate, on a vehicle costing in excess of $100K there is no harm in replacing a $4 drain plug on a once a year oil change.
Your choice, replace if you wish. I keep one as a spare just in case and sure enough my friend needed it. Things like that I buy from Porsche, not ebay or Amazon, etc. I realize Porsche does not make them, but they do have standards. Just look at the new "spares" all nicely red anodized drain plugs that my friend had on hand that would not fit.
Before I swapped to the Stahblus valve, I ran this valve over multiple oil changes and just swapped the copper crush washer and it was great!
https://lnengineering.com/products/d...e-s-turbo.html
Use common sense- Aluminum to aluminum , with 37 ft/lbs torque. I will just spend the $4 for a new drain plug and crush washer.
Alternatively, check your Porsche technical manual is you need a confirmation.
UPDATE:
I kept a close eye on the oil drain plug and noticed some seepage. Replaced the "upgrade" brass one with one of the old plastic pieces I had on hand. I realized when I used the brass style, I didn't feel the click when it seated into place like I do with the plastic ones.
