2019 911T: No sound from speakers
Help! I took my 911 out for a drive this morning and I couldn't get any sound from the speakers.
I tried different audio sources, FM/AM, bluetooth, Carplay, checked to make sure it wasn't muted, shut down the car completely and restarted more than once, all to no avail.
Any ideas on what could be the cause?
Thanks for any help.
standard audio or bose/burmeister? If bose/burmeister there is a separate amp under the passenger seat, with a separate fuse in the passenger footwell fusebox - check that. If it is the standard audio, the amp is built into the pcm (headunit) so not a fuse since that is powering up...
SS
The following 3 users liked this post by S S:
