Getting Android to work?
I have a 17 911 and 18 Macan both with Apple Car play. My Android phone works in both but not Spotify. Will I need to get a I Phone to get it to work?
If you’ve done the simavers or DIY android auto enable in your 911, no, you should not need an iPhone - I use spotify on android auto in my 911 every time I go on a long drive with it. Works just fine.
Use the guy on here that does it, he did my 17 911 and its great. Also did my 18 Panamera
simaservis1108
simaservis1108
thesaintusa (12-08-2022)
Agree. Get Android Auto via Sima. He has done 2 vehicles for me.
Just for your info, the first time I experienced a lot of no connection/disconnection problems. Online forums suggested the USB cable. Tried about 5 or 6 different expensive cables. No different. Bought a Motorola MA1 wireless AA adapter. Worked, but used to disconnect the phone at certain locations, typically near known speed trapping locations, so Waze would not work. Not cool. Suspected RF interference with the MA1.
Changed my phone from a Huawei P20 Pro to Samsung S22 and the problems disappeared. AA works fine in my SUV with factory AA and the 911 with Sima AA update.
I was asked to use the OEM USB cable and I have a Samsung S22 Ultra so I used the cable that came with my charging brick and it is native USB-C. Also did not work or if it does, it's sporadic when it does.
I was told to factory reset the PCM which I will do soon.
I also have the Motorola MA1 wireless adapter and it connects to my S22U phone via Bluetooth. The phone says "Connected to Android Auto". "Continue on your car's screen". But there is no pop up for carplay showing up on the PCM. I know when it worked via USB cable the pcm shows carplay not Andro auto.
Anyway I'll work with Sima to figure it out eventually.
I'm having a similar experience with Android Auto. It worked initially with a USB cord but the next time I was in the car (2021 Macan) it did not pop up Android Auto.
in phone settings, go to Developer options and enable - you will find instructions online how to do this.
In Developer options, there is a Default USB configuration setting, choose Transferring files.
Try again.
I have the same cars (a 2015 Macan S though) and no Apple Car Play. I think the 911 has it but I have no Apple devices so haven't tried it.
My android phone, including Spotify, works fine just using the bluetooth/AUX setting on the PCM. I agree that Android Auto is the way to go, but if you just want music (and GPS through the speakers) the BT source works perfectly. It automatically connects to Spotify when I get in either car.
It is different for each phone, so I won't give exact instructions, but try this:
Try again.
Try again.
I do get a bit jealous when my fiancé gets in the car and her iPhone automatically pulls up Car play. Being an engineer myself, I don’t think I can ever use an iPhone though…I like my customizations too much.
Developer options (I guess) are off by default. Otherwise the average joe will have the phone disabled in a few hours...
If you don't know what a setting is, don't mess with it. Only the USB file transfer change should be necessary. If AA works, turn off developer options with file transfer selected. If AA stops working, you may have to leave developer options turned on.
Unfortunately most 'Android' phones are running the phone makers Android version which is not necessarily what Google configured to work with AA. You may need a Pixel for that.
I used to be a long time user of pixel phones since the pixel 2. I got burned with the pixel 6 pro..no connection, poor battery, the crappy exynos modem they used, etc. I had to replace it and the Samsung has no issues. Hopefully I'll go back to pixel with the 8 pro whenever that one is released and hopefully they will improve on things from the 6 and the 7.
I reset the PCM in my Macan, reconnected my phone and the Motorola MA1 now connected and Android auto popped up.
Let's see if it will auto connect now when I get back in the car at the end of the work day.
This is a new, but known, issue with Android Auto on the latest release. There are so many bugs related to Coolwalk. I'm sure it'll get sorted out on the next AA update.
I forgot to ask, what is the difference between Sima’s mod and another vendor I see on here? Can warranty be void by going with one vs the other? I see posts about a fake FEC code being activated in the PCM. If I bring my car in for maintenance, and they hook it up to the computer can warranty be void?
I had a service done under warranty and the car was returned with AA (software) working. I am not sure how obvious the AA SW upgrade is to the diagnostics, or if Porsche even care. The 992 has AA, so it can't be that bad. IIRC, Porsche didn't want to add AA for earlier PCM's due to a security risk with Android.
AFAIK, the PCM can be restored to the original setting if you only did the AA SW update.
Adding AA hardware is more likely to cause some problems under warranty.
The only other issue I am having is well, my fiancé is an iPhone user and she often drives the car too (in fact she prefers driving the Macan now, go figure). When she gets in her phone is paired with the car and my Macan has wireless CarPlay which came with the car when I purchased it. It works fine but when she is done and then I get into the car to go somewhere, for Android Auto to pop up again on the PCM i have to reset the PCM, reset the Motorola MA1 adapter, and reconnect my Android phone and then Android auto comes back on the PCM.
I asked Sima and he said he will look into it. Seems to be some mix up in the PCM once CarPlay is connected. Before her iPhone paired with the car, AA wireless came up for me every time I got in and turned the car on.
jeifei72 (03-22-2023)
