Alternator belt after water pump
it's a serpentine belt, so it was removed and reinstalled when the water pump was replaced.
with just "an issue" as info, it's hard to say. could be standard maintenance required -- belts wear out and age out. could be contamination from the water pump removal. could be improper installation.
I've only gotten the squealing belt once when I went through a good size puddle of water.
The belt has a tensioner on it so it will not be too tight...... but the tensioner could go bad and not put enough tension on the belt allowing it to slip a little.
Did it correct itself or did the dealer have to remedy the situation?
It's pretty hard to mess up tension and alignment. Could be an entirely unrelated incident, like the PDCC (or PDCC dummy) pulley seizing.
Should probably bring it back to the dealership, especially if your water pump replacement was recent.
it's at the dealership that did the water pump. Hopefully it won't be there long....but they probably won't even look at it until next week.
I had to have my tensioner replaced during my last belt change (135K miles) because the plastic pully was worn,
CSK 911 C4S (09-14-2022)
