Fluid leak question
Fluid leak question
Hey guys. Recently picked up a 2013 911S Cab. It’s a high mileage car(103,000…great build sheet though). Drove the car back from Houston without any issues (averaged 29+mpg). Got home and let the car sit for a while. When I went back outside I noticed a reddish/pink fluid on the floor. It’s got a thicker consistency than water so I don’t think it’s coolant. Probably power steering / transmission fluid based on color and scent. I think I’ve found the source for the leak, but I can’t tell what part this is. Location of the part is on passenger side. Any help would be great.
It's tough to figure out from your pictures where this is.
The only pink fluid that I know of in a 991.1 is coolant. Does it smell sweet?
Edited: Corrected and deleted my comment on PDCC the fluid is yellow as stated below.
CSK 911 C4S (09-11-2022)
I know you said that you don't think it's coolant but have you even bothered to remove the coolant reservoir cap to see if the coolant level appears low? If it doesn't, then your hunch about it not being coolant is right. But I would start there because Porsche brand coolant is definitely pink.
I didn't see where you stated the transmission?
PDK uses two types of oil. Gear and Clutch pack. The clutch pack oil can be red in color.
If the fluid dries with a white crusty residue it's coolant. I'd see if it mixes with water as stated above.
