Testing Brake Fluid
What is considered a good brake fluid tester?
For those with electronic brake fluid tester, you could see how off it is by using some left over unused brake fluid when changing it out or buying a new bottle and adding water. Someone check my math but wouldn’t using 100ml of new fluid with 2ml of water be 2% on electronic reader? You could then add 1ml at a time and see if 3 ml of water registers on the tester. I volunteer someone with an electronic tester to do this. Thanks in advance.
