blue smoke on start up
Cold start this morning
https://youtu.be/RA6cvWKqlzg
thus far I've gathered:
- no overfill alert
- smokes 1 out of 10 startups
- don't have an MFD (!?)
- checked the oil and it was overfilled (how?)
- read somewhere about someone having too much oil so you decided to drain some oil
- currently showing full oil, after having drained some oil (again, how?)
some of these things directly conflict with one another. how do you not have an MFD? did you delete it? if so, why? do you have a dipstick installed?
there's so much missing context here and the thread reads like insanity as a result of this. it's great the issue is maybe resolved, but for posterity it's extremely helpful to clearly state what happened and the steps taken to rectify it.
there's also the problem that sometimes smoking at startup is not something that overfilling would generally cause, unless the smokey startup is immediately after beating the crap out of the car, which you seem to do with regularity, so a 1 out of 10 smokey startup scenario seems unlikely.
- no overfill alert
I have done some pull yesterday and you saw my cold startup this morning...As you can see my oil is full but not on the top
i have done like 20+ startup now and absolutely no smoke...
I assume it read full, but not overfilled, when you first looked at it before you drained oil, too?
if so, I don't think it's defective, I think you were simply in the margin of error range before it alerts for being overfilled.
Im sitting my car for 2days now then i will fired up and see if it smoke again i will update this thread if smoke come back...
