FVD Brombacher Stainless Steel Brake Lines for Porsche are manufactured in Europe and are approved for all ABS systems. They consist of a PTFE Teflon inner liner surrounded by a stainless steel (INOX) braided cover. They are also coated in a UV resistant PVC jacket to protect the braided wire and inner hose from the elements, chemicals and abrasion. This construction ensures minimal expansion inside the hose core and eliminates that “spongy” brake feel that is commonly found in the OEM brake lines.
FVD Brombacher has been tuning Porsche vehicles only since 1984, so rest assured that our lines are a direct bolt on replacement for each Porsche application.
Features:
Brake with Maximum Efficiency
Resistant to Brake Fade and a Spongy Brake Feel
Durable and Dependable for Street or Track Use
Direct Bolt on Replacement
Set Contains:
4 x Stainless Steel Brake Hoses
1 x Installation Instructions
1 x General Operating Permit (ABE)
FVD Stainless Steel Brake Lines are THE BEST WAY to transmit hydraulic pressure from your foot to your brake calipers with maximum efficiency and durability. Experience the difference today!
