60-130 record for à 991.2 carrera ?
Just did my best time 60-130 realy happy with the result
Fuel 94oct+ meth
Drver 240lb
3/4 fuel tank
Car full weight
I think APR did 5.85 at best with ton's of mods and weight reduction
Log here:
https://datazap.me/u/991ff/log-1654185436?log=0&data=5
@AlexZTuned
The following 4 users liked this post by 911f:
The following 3 users liked this post by 911f:
Just a bunch of First gear burn outs?
I remember doing burnouts in my RX-7 standing on the brakes and feathering the throttle wishing I had a line lock haha. Made a HUGE difference heating up the Nitto drag radials. Even cold they hooked better than a normal street tire.
Your car is hustling!!
Thx you sir ,so yes i warmed my tire with à few launch and it started to hook (1.81 60ft)in first gear but could be alot better ,secound gear no problem it hook so i need to go to à proper 1/4mile prep track ,im curently at 32psi on michelin cupR
At the track i will lower pressure to 25psi and see how she does and lower if needed ,my goal is 1.6-1.7 0-60ft that should put me easy in high 9 sec i hope
@thesaintusa
@thesaintusa
Lol no more sensor to data the ecu exept bank1 oxygen sensor still alive bank 2 dead my mecanic supose to do it soon i hope all i need is good fuel,meth ,good ignition timing and of corse boost 😉
Fuel 94oct+ meth
Drver 240lb
3/4 fuel tank
Car full weight
Log here:
@AlexZTuned
> 100F temp and > 2,000 DA and no slope
I wish i could have E85 or E40 here :/ but my fuel setup is the best i can get here ,meth is cheap here and you use it when needed ,E85 for a dayli drive car is not the best from what i have read but is the best for race purpose
