991.2 NON PSE Exhaust
I have a 2018 C4S Non-PSE Coupe. I just purchased the car and have had an APR tune done. Like others, I'm looking for a way to improve the exhaust sound a bit without spending insane money or creating an obnoxious sounding beast. Will sport cats alone help? Who makes direct bolt on replacement cats that will work with the OEM resonator? I really don't want to spend $6,000 for an entire system from Soul or Fabspeed, etc. Seems like there are more options for those cars that came with the PSE system. Any help will be appreciated.
A question about APR tune as well. Does the full horsepower and torque boost only kick in when the car is in sport mode? Does normal mode essentially remain as the stock power levels? I'm just trying to understand how that file modifies ECU. My car is a manual and I elected to get a reduced torque file installed and am not sure of the final performance numbers.
I appreciate any input I can receive.
Basic Sponsor
Thank you for considering our rear exhaust! Unfortunately the impact of modifying your catalytic converter sections will not be as great as a PSE car which has a straight shot flow path out with valves open. I will say that our Performance Exhaust System went through extensive testing to develop the anti-drone tubes to target the specific drone range inherent to the 991.2 - over a dozen variations were tested until we ended up with our optimized result. I wouldn't recommend running upgraded cat sections without some way to attenuate drone. If you're looking to do a package deal on everything, we're happy to work with anyone on the forum to get you the best results and best pricing. We're always here if you need us.
Most ECU tunes will allow the vehicle to operate under more aggressive timing, fueling, and cam phasing parameters among other things. You will notice some more grunt and a more immediate engine response from these changes and then a massive gain in power with the increased boost targets. We use Softronic as Scott has experience tuning factory Porsche race vehicles, you might want to give him a call to discuss.
-Mike
-Mike
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
johng@soulpp.com
jwheel@soulpp.com
-Mike
-Mike
Basic Sponsor
As for the APR software, I'd suggest giving APR a ring and reviewing that topic specifically with their team. Nobody here on the forums is going to answer your question better than the fellows that actually designed the tune you're using on the car, and from what I've heard they're friendly to chat with.
Regards,
John Gaydos
