Headlight adjustment on lowered car?
Do the headlights automatically adjust to a new level position when a car is lowered or do you need to manually adjust the lamps? I have a 991.2
manually realign
Would the amount the car is lowered actually matter? The light beam angle is like a half a degree down from the horizontal for most all passenger cars.
Likely this isnt much of a change if you just lowered the car but none the less, good idea to check how it feels at night and do an adjustment if needed.
The DOT has rules/laws to help with aiming headlights correctly. This is a handy guide with easy to understand diagrams you can use to check if your headlights fall within spec or not: https://www.fhwa.dot.gov/publication...148/aiming.cfm and if they’re out of spec, then adjust them so they are correct. Pretty simple.
