Joyauto question
Hello All.
I have Joyauto CarPlay in my 911.1, it's been over a year now. I was under the impression that once set up, CarPlay would auto connect and pop up on the screen. I have to go through a variety of steps to get mine to work, first I hit the Navi button on the PCM screen until the Joyauto menu appears, from there, Setup>Bluetooth>Devices>iPhone, then it will connect. When it works, it works great. However, sometimes the audio won't play and I have to reboot then all is back to normal. I've contacted Joyauto through What'sapp and they don't respond, also searched the forum
It seems that it would be a simple setting or there is something that I'm just not getting correct.
Has anyone had the same thing happen or know any possible solution/s? Any insight is appreciated.
Make sure to turn off the PCMs Bluetooth. Joyeauto should auto connect after the first time you’ve paired it up, it just takes 30sec or so. And it should auto switch the screen into carplay. I don’t press any buttons.
Bayern991 (04-30-2022)
