Another great experience with Zunsport
Just installed my 991.1 S grill kit. Once again excellent fit, super easy install, and it arrived in Florida from the UK in less than a week. They look absolutely factory. Still don’t understand why Porsche doesn’t put them in as OEM.
Do you have pics?
i just installed mine, I didn’t install the middle grill due to fitment issue. I was told they have two gts version : one for third radiator & one for black plastic.
i have the black plastic so I’m not using the middle part.
Looks sweet. I gotte get mine installed at some point
OT: if your trickle charge terminal cables are long enough, you can divert the socket to the base of your windshield on the passenger side and avoid having to pop open the hood everytime you plug in
spyderbret (04-19-2022)
Yes slight gap when first put in. Didn't bother me because on a walk around I'd have to point it out. Now since 6 months to settle in, I adjusted it and reduced it to barely noticeable only if you crouch down to see it. No trash, birds or cigarette butts in the radiators so glad they are in.
My middle grill didn’t fit at all. I would need to shave the tabs. They gave me a partial refund.
I think I can live with no middle grill cuz the middle part is closed by a black plastic. No third radiator on my car.
I have a third radiator so I was installing it in with some tolerance of fit in exchange for better protection. I figured I could (and ended up, did) form it better into the upper lip but definitely the center fit is a source of some comments . Good they worked things out with you.
But since it’s only plastic , there is nothing to protect back there .
They offered exchange but I had to pay shipping back , so I took the partial refund . All good. Will give it another go once I shave the tabs/ brackets .
Here are some pics from my Bodyshop . They couldn’t make it fit with the tabs.
