I’m running 36/44 on .2 C2S (same wheel/tire) specs as C4/S/GTS. PS4s on mine.
I tried 33/36 but felt the car was too soft. Yes, more comfortable on local (crummy roads), but too much of a nimble feeling compromise for me.
Most published specs I see for our staggered wheel/tire spec is 34/44 regardless of tire brand. I’m going to put my trust into these baseline numbers vs personal opinion.
Just picked up a set of PS4S's and running comfort mode and wondering what pressure they should be at? Currently 45 in all four.
so.. "comfort mode" is just a TPMS target pressure. It won't yell at you for being overinflated, which you currently are. By a lot.
If you go into the tpms menu on your MFD, you can see the target pressures. It will tell you the difference between the read pressure and the target. Adjust accordingly.
31/34 cold, warmed up they are 34/36...super happy with the traction and handling...
I daily my car with lots of spirited driving as well as urban driving. I'll be replacing my rears with around 11k miles on them.
