Switched 5A fuse in 2018 991.2 GTS Cab?
Hi all
Looking to hardwire a dash cam into the fuse box and am trying to identify the best 5A fuse to piggyback onto. Should be switched w/ignition to avoid battery drain, but I am challenged to identify which one fits this requirement (I.e., no power through the fuse circuit when ignition off). Tried using the compass circuit on the passenger side but alas this seems to be live even when ignition off. Any help appreciated.
JCF
JCF
I used spot C4 and D3 for my dashcam. Don't remember which was switched, but you can check with a multi-meter.
![](https://fuse-box.info/wp-content/uploads/2018/12/Porsche-911-991-2012-2016_in_R.jpg)
C4 Cabriolet: Rear right power window control panel
D3 PDCC control panel
They aren't 5amp, but I used add-a-ciruits.
![](https://tse3.mm.bing.net/th?id=OIP.ZGRoNMN7tg1Y_Z83yg64KwHaF6&pid=Api&P=0&w=300&h=300)
Good luck.
Good luck.
Thanks for the quick and helpful reply. Using my multimeter I was able to identify D6 in my particular vehicle (passenger seat ventilation, 5A) as switched. Working as required now. Seems the rain sensor (B1) is unswitched! That was a bit of a surprise.
Thanks again
JCF
Thanks again
JCF
Speed2k (03-30-2022)
