Preemptive ABS
#31
4 Point 0 (05-01-2022)
#32
Then the front would collapse on turn in and the inside rear wheel would just light up.
So i went 100/150 and it is awesome. But i now want more. I am trusting that tractive is making it livable on the street, so i can go more than i usually would for track.
Some GT3 guys with tractive are reporting good things with 130/200. Thats some big boy springs there. I am thinking thats too much for the street, but tractive with DSC really has expanded the possibilities.
#33
You should consider decreasing camber if you do that because you’ll have less dynamic camber with stiffer springs. You’ll also regain straight line traction. Your camber might actually be the cause of some of your traction issues in situations in which you’re not fully loading a side.
#34
The tyres will tell the storey. Even with almost 700hp, straight line traction isn’t an issue. Its only coming onto the straight, and its only once the car is hot. I am thinking it could be a cooling issue. Maybe the transmission is getting too hot.
Prior to the OS Giken diff, I got a front diff failure error. Which is quite funny, as i don’t have a front diff. Mine is RWD 🤣. I think the E-diff struggled and over heated and would give up.
Up grading the turbo’s actually helped with traction. By moving the power curve to the right, its no longer explosive power down low. Its smoother and seemingly endless power as max power is actually redline. Which means once i have more cooling, I can tune it further and have even more. 🤣
