Preemptive ABS
Well, due to a complete lack of ability to get N-spec Cup 2s, Pirellis or Dunlops over here, I'm getting a set of K-spec's for my car - standard size 245/35ZR20 and 305/30ZR20. Hopefully this will not impact my handling too much. Kinda frustrating that we seem to be having persistent tire availability problems. Actually it was worse than that - I found a set, got them ordered, only for 1 of the rear tires to literally "go missing" - the shipper lost it irretrievably, so I wound up with 3 tires instead of 4, with no hope of getting the 2nd rear tire, at least in N-spec. So I took the conservative option - sent all 3 back, and am waiting for 4 K-spec tires to show up. At least they will be consistent in their stretchiness ...
Fortunately the local dealer ordered a lot of N-spec Cup 2s for themselves, but depending on the year that supply usually is gone by mid summer.
Completely agree that the tread width of the N-Spec tires (PS4S, P Zero, Cup 2) seems wider than standard tires, and other spec tires.
I would have done the same and sent back the 3 tires and gone with 1 version of the tire. What wheels will you be mounting them on?
Availability definitely seems to be regional.
Well it’s actually worse than that. Not only have i increased front by running N-Spec (Porsche) 265/35/20 front, I couldn’t get N-Spec rear. So I went K-Spec (Ferrari) 305/30/20 on rear. If you don’t know the difference between N-Spec and K-Soec, Porsche run 12 inch rim and Ferrari run 11 inch rim, and it shows. The K-spec look stretched.
So I have most likely decreased the rear and increased the front.
Mercedes Black Series have a 335/30/20.on a 12 and it looks flush. If I ran that, this time around, that would help?
It would be bigger than K-Spec anyway.
Yes its **** that you can get multiple 305’s all different sizes.
Since the K-spec is designed for an 11 it is most likely a 285 branded 305. Which means even if its a 30 it will have a smaller diameter than the N-spec one.
4 Point 0 (03-31-2022)
I may try a 325/30/20 temporarily and see if it helps.
Once this set is done, I’ll return to stock, matched size and see if issue gone.
This was never the plan. It has all been caused by lack of supply.
The following 2 users liked this post by 4 Point 0:
enzotcat (03-31-2022),
thesaintusa (03-31-2022)
Yes, I do believe it is causing interference when i come onto the straight. I run full traction control OFF. But it appears something is still trying to intervene. If the car believes the rear is spinning due to increased front diameter and reduced rear, than perhaps it is applying rear brake.
I think having K-Spec front and rear with stock sizes you will be fine. I’m N-Spec 265 with K-Spec 305. Front is most likely larger than rear due to K rear being smaller than normal.
Enjoy your informative posts
Took my 911 out of 'winter storage' today and went for a spin after work. Have an appointment to get my P Zeros replaced with Cup 2 and looking forward to trying them out. The cooler temps (right now) and the worn P Zero were not conducive for putting down the power.
4 Point 0 (04-01-2022)
CR-S
This is a 325/30/20 beside a 245/35/20.
The 245 is only just smaller. So the 265 i was eunning must be a fair bit bigger than the smaller K-Spec 305.
So it may have been causing an issue.
Will pick the car up tomorrow with the fresh rubber. Just git these new CR-S to test sizes, and have some fun skidding them. 🤣
They are half the cost of the normal Cup2-R.
Guilt free skids.
enzotcat (04-05-2022)
Fun thread. Thanks for the discussion.
So as above you can see how stretched the K-Spec 305 was on the 12 inch and how puffy the 265 was on the 9.
Now compare to how these both sit flush.
Rear 325/30/20
Front 245/35/20
Rear 325/30/20
Front 245/35/20
Here’s what the 305s (K2 spec) look like on the rear of my car - just got them fitted today.
That said, I rather suspect that it’s 11.5, which would explain why they don’t look as stretched as yours.
Terminology
| | Flush. | |
/ \ Stretched. / \
( ) Bulged. ( )
Also known as baggy.
| | Flush. | |
/ \ Stretched. / \
( ) Bulged. ( )
enzotcat (04-07-2022)
I have similar upgrades to you (100/160 springs, Tractive, Giken mechanical LSD, big brakes, though the PFC cup challenge brake kit), though on a base carrera with the base ABS module. Just like in the PFC video that you refer to, if I don’t brake smoothly and just smash the brakes, with lots of camber I will get what feels like a “rolling” ABS, not shudder, which I believe to be reduction in brake line pressure in advance of lockup. I’m just referring to straight line braking, not traction control issues you describe while on throttle. This brake line pressure change is apparently a function of ABS module calibration, which is different in our lesser models than GT3 etc. As for your larger tires - it’s understandable if preemptive ABS would kick in more, as it does with better brakes - much better grip means faster increase in G forces during braking and turning, so you’re likely passing the lower traction thresholds that are baked into our ABS and TC modules.
I am thinking of going 120/170 next, and changing the helpers to tenders. Tenders aren’t fully closed with body weight at rest. It is supposed to help with traction.
I love to experiment.
