3rd Brake light wiring harness part #?
Does any one know the part number for the 3rd brake light wiring harness for the up/down spoiler on the 991.1? Mine is a 2014 C2S.
I've had a Techart II wing installed for a bit and am finally getting around to wiring the new 3rd brake light in with a 3x3 flasher module (I got rear-ended last year
I want to leave the existing wire as is for easy complete reversal of my mods for myself or next owner. I want to pick-up another 2-pin connector to add onto my newly run pos/neg wires from the splice inside the shelf in the cabin.
Anyone keen on this?
Thanks!
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Thanks!
That seems like a lot of work to accomplish something simple. You can tap into one of the existing license plate wire pairs using . You'll just need one of
to drop from 12v to 5v. You also need the connector that goes to the strip and some 20g wire. That's how I did it. If you want to reverse, just remove the assembly. I posted some pics in the 3rd brake light thread.
That seems like a lot of work to accomplish something simple. You can tap into one of the existing license plate wire pairs using these. You'll just need one of these to drop from 12v to 5v. You also need the connector that goes to the strip and some 20g wire. That's how I did it. If you want to reverse, just remove the assembly. I posted some pics in the 3rd brake light thread.
The connector that goes to the strip is EXACTLY what I'm looking for! I want a second one to connect to my assembly and just be done.
This one:
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1210x907/fixed_824935444f7e72370144d79f10242d7a811031ee.jpg)
