PCCB: Center lock wheel mount pin tool
Hi all, I saw there is a tool available to help remove centerlock wheels. Does anyone have this tool? I'm considering it, but, $365 seems like a lot of money for a piece of aluminum. I'm slightly considering using a 3D printer to make my own, at a considerablly lower cost. Has anyone attempted this? lol, I know, I'm crazy. If someone has one, or knows the diameter of the tool and the centerlock thread specs, I could try and make one.
You're not the only one... I spent some time searching around hoping to find a file to 3D print. I have iron brakes, so it's not as essential for me to be careful putting wheels on/off, but it would still make the process easier.
CT_Peter (01-18-2022)
I still make the best CL alignment tool out there for the best price. PM or email me at ed.jenkins@comcast.net for details.
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/pxl_20220127_041932003_3484e330fe1ef96f10418d88216fa15a640ce5ac.jpg)
If you have iron rotors and wish to change centerlock wheels, this wheel alignment tool is nice to have. Especially if you are prone to lower back problems. These 19" and 20" wheel are very heavy, at least 50 Lbs.
If you have PCCB rotors, Ed's alignment tool is essential. All it takes is one screw up removing the wheel where it collides with the PCCB rotor and creates damage...ouch. If it's bad enough where you have to replace the rotors, you'll beed to replace rotors in pairs, a mere $10,000. Ed's alignment tool is cheap insurance.
I have Ed’s as well. Super nice. Solid hunk of Delrin. I’d be worried about a printed part fracturing at the thread and shaft juncture and then you have the exact problem you were trying to prevent and barrel damage as well.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1014x1599/center_lock_tool_fd74f297c3fbb18be98d93614228d8347e72a5cb.jpg)
Thanks guys still available, PM me .
Suggest you list these on Marketplace. I’d seen references to them and even checked there, no luck so figured they were NLA, and went for the Suncoast one. It’s fine but ridiculously heavy, not tapered as much as yours to aid guiding the wheel on, and still metal on metal sliding the wheel in place. Yours looks like a better design for sure.
Another plug for Ed’s. Excellent quality. Good value.
Since this popped up again, I’ll say thst this is super well designed and super stout. A 12” 305 rear has some weight to it so knowing that the caliper and rotors won’t get bonked is reassuring.
