991.1 LED DRL issue
991.1 LED DRL issue
My 2016 GTS has PDLS+ with the LED surround. The rings illuminate when the drivers door is opened, but I just noticed the DRL ring goes off after startup. I checked the lighting menu for a setting for Exterior Illumination, but there doesn't appear to be a setting for this. Any ideas? Something faulty? I did just install grill screens which required removing the bumper cover, but everything went back into place. Should I check anything? Headlights work for all phases - hi-beam, low-beam and fog lights. Side markers illuminate as well.
OK after a little research, I guess I was under the misconception that the DRL rings four lights stayed illuminated under all lighting conditions. It seems they do not stay illuminated when the headlights are on. Hence the daylight running lights name. I did think they stayed illuminated as they do for the 24 hour Le Mans cars. Thought that was a signature design for them.
