Brake fluid replacement procedure
I’m upgrading the brakes on my 911 T with Essex 350mm rotors, Spiegler lines and Ferodo DS2500 pads. I’ll be replacing the Porsche brake fluid with Motul RBF600. Is the proper procedure to flush the brake system with the RBF600 fluid first, then bleed the ABS system and then flush again to get the ABS fluid out? I have the Icarsoft v3 diagnostic scanner and Motive brake system bleeder. Thanks!
Replace your components 1st then bleed out and flush with your new fluid.
Don't have to do anything special with your ABS pump unless you change out your ABS pump.
The following 3 users liked this post by CSK 911 C4S:
