991.2 headers, bolts vs. studs?
Sorry for my bad math! 9 per side so 18 total - makes sense. 2 spares are never a bad thing, On the second header install I did, we reused the OEM hardware, Completely fine.
I would recommend just sticking with OEM gasket. Thats what I will do if and when I remove mine to redo the gasket/studs.
LWG (12-18-2021)
I should be getting the 51 mm ones by Wednesday so we’ll see, hopefully they won’t be too long to interfere with the tubes and allow the short 12 pt socket I have to go all the way in to engagement. I’ll update next week.
Couple of pics for fun.
Tier1Terrier (12-19-2021)
Don't back out the stud. Doing that, you lose the benefit of using a stud. It needs to be properly installed/seated into the threads. There should be install instructions to follow from ARP, or maybe on their website.
We've not installed Soul headers, but if you have a stubby flex socket you should be good.
51mm might be a little long. Just curious if you will be able to slip on the headers with 11mm extra length over stock. The 45mm might be the best length.
@VektorPerformance do you reuse original OEM manifold gaskets when doing header install or you use brand new gaskets? I inspected the gaskets I removed from my 10K mile car and they see, "fine" - but if I am going to redo the job I dont want to take unnecessary risks.
F1SML8R (12-24-2021)
OK, I can confirm that the ARP M8x1.25x51 studs work in our application at least with the Soul headers. They embed all the way in the heads, and obviously plenty of outside thread to engage the nut fully with some to spare. The 45 mm ones would have been ideal as the 51 mm make it a little harder to mount the header (just have to push the turbos out a little more to clear the turbo studs), and get the nuts and sockets over them, particularly on the passenger side header, but nothing too terrible. I would have gone for the 45 mm if they were available, but again everywhere I looked, they seem to be backordered till February and can’t wait that long, need to get this part of the project going and get her on the ground someday soon and test it. Too impatient.
Pics:
ARP 51, OEM stud (41) and ARP 38
Final location of the nut after accounting for aftermarket flange and ARP washer.
Used Nickel antiseize and snugged them down. These things as quality hardware no doubt.
Jut enough engagement to reach tightening with a short 12 pt 10 mm socket and wobly extension.
Happy with the end result.
Pics:
After doing this, I would say, as Vektor and others in this thread had pointed out, that if you don't wind up pulling studs off the head when you remove the OEM manis, and the outside threads look decent on the OEM studs, I might just have run 12 pt replacement nuts (rather than the tripple square corroded OEM nuts) over the OEM studs and called it good. But once I pulled one of the studs, my OCD kicked in and I decided to go this route. I plan to keep this 991.2 for ever (pretty much), so since I had her up on the lift at home, and no huge rush, I also wanted to get the best hardware in the event that I have to pull the headers again down the road, and ARP is as good as it gets in aftermarket hardware, and can be reused if the studs needed pulled out. Again YMMV.
991_T (12-27-2021)
tx-911 (12-23-2021)
Figured I post this here for record keeping in case it helps someone down the line.
Today I finished installing the headers, used the brand new gaskets supplied by Soul on the head side and the turbo side, I put anti-seize on the threads of the studs as well as the washers.
I then torqued the head side nuts in sequence, starting at the center and moving to the outsides which made the most sense from what I read, I did three rounds at 11 ftLb, 15 ftLb and a final 18 ftLb. I plan to come back and re check torque spec after the first two hot/cold cycles.
Below are the part numbers for the OEM gaskets for reference. On the turbo side, I elected to keep the OEM studs, I simply tooked them off and wire wheeled them, except for that bastard one on the top driver side where I’ll use one of the bolts supplied by soul. Soul also supplied new copper clad nuts which is what I used.
I left the turbo side loose until I mount the catless pipes.
Head side OEM gasket: 9p1 251 261
Turbo side OEM gasket: 9A2 111 215 00
Turbo side studs fore/after wire wheel.
The money shot.
The money shot.
polobai (12-26-2021)
Basic Sponsor
Thank you, @TX 911, for choosing SOUL and putting in the time and research to find an alternative stud solution. We may offer this as an upgrade with our headers. I'm sure the forum would love to see the results of any other endeavor you choose to tackle, let us know if we can work with you to continue to bring more information to the forum!
-Mike
-Mike
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
johng@soulpp.com
jwheel@soulpp.com
tx-911 (12-27-2021)
