Oil measurement
Oil measurement
Odd question, I understand to get a good reading you get car up to temp and then shut off for a few seconds and then turn the ignition on (don't turn engine over) and get the reading.
Today, I got in the car after sitting over night and for craps and giggles I started car and went to the check level screen and it showed oil level VS the standard message about not being able to take reading. Is this normal?
Also I notice the readings, when engine is warmed up varies a little. Anywhere from 3/8's to 5/8's on level ground. Normal?
I love the car, but it does seem to have some gremlins in the electrics...case in point I get random loss of Bluetooth when listening to my playlists from phone. less then a second.... weird.
Thanks for the help.
All normal. Lots of threads about this if you want to do some reading.
The car takes measurements periodically and will show you the last measurement when you go to that screen. If you open the engine lid, the assumption is made that you modified the oil level and it discards the last measurement it took.
If you're anywhere in the green on the measurement, you're fine.
Regarding bluetooth...make sure you try a different app on your phone...the same thing would happen to me, but with only 1 out of my 5 most used music apps...pretty frustrating until I realized other apps had no issue.
NI3 (11-02-2021)
Thanks Mangu. Will give a try.
