Adding Multifunction Controls to 991.2 Steering Wheel - Complete DIY Video
No issues leaving the original stalk. It continues to work as it used to. I really felt no reason to remove it. Just gives another option to control stuff.
I was not able to configure the custom (wild card) button but for me it functioned perfectly as it brought the display back to the baseline gauges which is what I like. So if I were to have configured it, it would have been to work exactly as it does.
I followed your process and it went very smoothly. Very happy with the result. Mine was a relatively simple swap out of silver trim buttons for black, to match the surround. No control box or function issues or changes.
dc7391 (05-17-2023)
Good upgrade, I have the same steering wheel. It was called the GT Sport Steering Wheel and cost $320. BTW, be sure to look at the oil change thread, more tips. It shows how to do it a better way than your YouTube video.
OP, thank you for the awesome video and DIY which was explained very well.
Silly question on my end, but does the type of speakers that come with the car affect the MF controls usage? I know most 991.2 models have Bose or Burmester audio equipped but mine has the non-bose stereo. I assume the infotainment and everything else would be the same?
Just wanted to make sure the audio controls and phone connectivity on the steering wheels control will still work on my model before I start sourcing the parts.
GT vs non GT
Does anyone know if the multifunction controls same from a GT versus a Non GT steering wheel since the Gt is slightly smaller in diameters? I see them on eBay but just want to make sure I get the right one.
thanks
thanks
They are the same, yes.
Quick question. I have a 2015 991.1 with basic steering wheel with PDK shifters on left and right side. If I find the same steering wheel, same configuration, Can i just swap one for the other without reprogramming from the delaership? Even if the wheel came from a Panamera, cayman or boxster?
Couldn't make it work.
Bought a wheel with the MF switches and module. My car is a base 991.2 non-chrono PDK. The wheel was said to be from a 991.2 non-chrono. Removal was easy, but the install was not. The airbag connectors were different so I couldn't connect the airbag. Installed the wheel connected the harnesses. Fired up the car without the airbag to test the MF switches and nothing worked. Am I missing something or did I get bad parts/wrong wheel?
I'll tag @polobai here as he has some experience with this an might have other ideas as to what might be causing your issue.
Not sure about that and I'm sorry to hear it's not working for you. I think you already know if it's from a non-chrono vehicle because it would be missing the drive mode selector dial. Did it come with a wire harness or did you use your original one? I think the module is key although I can't say for sure that's what your issue is. Could it be possible that one of the wires isn't connected properly or could a wire have gotten pinched? Just trying to think of anything that could be causing your issue. I think as a last resort you could take it to a dealer and ask them to code it for you but there's no telling if they will do that for you or how much that will cost.
