Waterpump leaking
If it's the tank vent again I'd start looking at lemon laws in your state, unless it's something silly like a gas cap.
You won't (well, shouldn't) pass tech inspection with a CEL on for your DE, by the way.
Have the 2017 911 3.8 Turbos also had these water pump problems?
Or is this strictly a Carrera 3.0 issue?
I should also mention my 2017 911 C2S had a small coolant leak I noticed on the garage floor a few times. I recently traded and that indie dealer took it into a Porsche dealer and they replaced the water pump under that warranty.
I have not heard or read about any 3.8TT water pump issues, or GT3's either. If its strictly the 3.0 tt's, that water pump design or mfr has/had a problem. I'm sure Porsche will fix it, but it seems to be taking an iteration or two to solve the problem.
Why does the tune affect the Tank Vent?
