2019 C4S Suspension System Fault
I have a 2019 C4S without PDCC or Sport Chrono. On Start Up today, a yellow warning appeared in the Multi-Function Display. "Suspension System Fault, Drive with Caution". With the PDK in Drive, there is also a piercing acoustical warning. Turning the car on and off produces the same result.
Obviously, this is a warranty problem. I cannot, however, drive the car to a dealer with the piercing sound ringing in my ears. I would prefer not to have the car flat-bedded there. Any suggestions as to what the problem is or how to turn-off or turn-down the acoustical warning to make driving possible would be appreciated?
On the MFD in the vehicle menu, push the button on the wheel (or stalk if you don't have a multifunction wheel), scroll down to settings, select, scroll down to volume, select, scroll down to warning tones, select, scroll down to low, select, you're done.
Video to show:
Video to show:
Thanks for the information
Thanks for the information on adjusting the warning volume. I can now drive to a dealer for suspension service.
