Active fuse in Slot that’s labeled “Unused” in manual
What fuse is this in my passenger fuse box #D5?
My manual says it should be “not used”, however, it has a 5amp fuse in it, and it has real contact on the other side. Unused fuses doesn’t have a real contact on the other side. Check out D4,D6, etc and you see there’s no contact point since my car doesn’t have these “options”.
My car is 2012 911 base with no options. It doesn’t have PDCC, so seat ventilation.
Could the #D5 fuse actually supposed to be D4?? D4 is supposed to have a 7.5 amp fuse and D6 is supposed to have a 5amp fuse, but I don’t have ventilated seats.
i found another thread here where Mjposner has a fuse in his as well.
https://rennlist.com/forums/991/1265...l#post17634663
