GTS Centerlock Delete?
Hey all, About to step back into the P world and have my eyes on a 2018 GTS. It does not have centerlocks and that doesn't bother me but see nothing on the VIN decoders that would indicate they were factory deleted. Has anyone that has spec'd a GTS seen that option? Thanks.
I'm not sure exactly what you are asking but plenty of folks have gts with factory 5 lug wheels. Seem to remember folks on the forum doing the modification after the fact. Wheels can be converted either way to and from.
bakerphoto (10-02-2021)
@bakerphoto, I ordered my 2019 C2 GTS without centerlocks, it's a no-cost option that is automatically selected when the wheel choice was changed from the standard GTS CL wheel to a 5 lug (the Carrera S wheel was ordered in my case) Look for the wheel design that car was originally spec-ed with, that should tell you all you need to know.
BTW - switching to a 5lug set up is not an easy or inexpensive change to make after the fact. Many threads here on Rennlist regarding that subject.
HTH,
-m
C2 GTS OEM 5lug set up (19' HRE R101s)
HTH,
-m
My '18 C2 GTS was ordered with lugged wheels. The Mulroney sticker shows: "Wheels Painted in Silver" and "20" Carrera Wheels". The option code numbers are 346 and 433 respectively. Nowhere does it specifically mention "center lock wheel delete".
OBTW, I also got the "No Sunroof" option.
The following 2 users liked this post by DBH:
bakerphoto (10-02-2021),
snake-gu (10-01-2021)
HTH,
-m
HTH,
-m
