Projector LED Door Light install
Its all R&R plug and play.
All you need is plastic pry tool to remove the old one.
Note that the old light on the bottom has spring clips but the new LED projector has tabs.
To unplug squeeze the little tabs on the right and left of the wire leads then it plugs right into the new projector.
When you install the new projector it kinda snaps in because of the new tab style retainers instead of the spring clips.
Here’s the projection on the box in the day
& here’s the projection in the evening
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/cfef5deb_a449_4fa3_b4c7_c27b1ed7b4b6_de0ec188a4845a43e9762fcaf3be72acf8308ab1.jpeg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/03604d7e_c38d_47ff_9550_61f73b1a6a5f_7a53b3ef62a47d9f800aaf9cc97b105929862068.jpeg)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1840x2000/800e3551_d9b0_4615_a6ce_d1c076d60177_2ace176e122ea03fe095828a958f08f42c4664a0.jpeg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1520x2000/21b28a5f_9517_4f9e_9535_90233f2d5577_7f16e34c334af326c3d9ce305fba281f6179cd45.jpeg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1840x2000/591b7bed_173f_4716_91fb_06979955cc4c_9b6bc301f56d16a6cbfac815946c4b4dfee62f96.jpeg)
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1905/fc43beda_db47_4aad_bc1c_1cc37585d165_4e28301517769af33f1bfa56f71e504509e0782a.jpeg)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/a93cc812_f7c7_477f_8c53_f2c45b37524d_451df0a3bfa51f54b7eb20757085ce20021cf7c9.jpeg)
