Whistle sound in downshifts
Good afternoon all — My 991.1 GTS does some kind of short whistling/hissing noise when downshifting if I’m not pressing the gas. If I downshift while my foot is on the gas it doesn’t make the sound. My feeling is that it comes from the symposer at the back — sounds like it is sucking in air… like a quick blow in a glass bottle.
Is this normal? something to have checked? My 981 S doesn’t do it for sure.
thanks!
thanks!
PDK or MT?
Ah, shoot. Not sure. Just guessing here, but perhaps it has something to do with the automatic blipping of the throttle? I have my symposer tubes blocked off so even if my .2 did this, I wouldn't know.
You can test that by having the car in neutral, holding the throttle lightly so it's steady around 3000 rpm (or wherever you are when this happens), then sharply and quickly stomp on the pedal to the floor and immediately let go of it. That's basically what the car is doing to rev match for a downshift, however if you're off throttle it's a smidge different.
Received 5,413 Likes
What year? If the 3.0 litre turbo, maybe you are hearing the blow-off valve??
CSK 911 C4S (09-02-2021)
Update -- doesn't do the sound if I put a cloth or otherwise shut the symposer hole at the back of the cabin... I think it's the sound of air being sucked into that hole suddenly. Also note I have my PSE vacuum lines unplugged (and sealed) in case that may be related... any ideas?
PSE vac lines would be unrelated, especially if they are sealed.
Ugh... annoying. I also wonder if has anything to do with the fact that I removed the sound deafening sponge and the plastic cover at the back of the cabin, precisely to get more of that induction/symposer sound... (but wasn't expecting that tube/whistle sound)
JLCarrera, I think we found your whistle. Please see post #11 here:
https://rennlist.com/forums/991/9340...f-991-2-a.html
