It is not stock or factory. It looks like an LED from a K40 radar detector/laser jammer install. However, there are usually two, but you don’t need two,.
You might check for a switch under your dash. If you have a K40 that it is a common mounting location. Does it light up all the time? Steady? Or does it flash?
