Apple CarPlay under iOS 14.7.1
Old Aug 1, 2021 | 12:52 PM
Kelsey's Avatar
Kelsey
Default Apple CarPlay under iOS 14.7.1
Hi all, was wondering if anyone else is having trouble connecting to CarPlay after updating their iPhone to version 14.7.1 for the operating system? CarPlay worked fine just prior to my update and now it no longer works. Thanks in advance.
Old Aug 1, 2021 | 06:09 PM
RichardA's Avatar
RichardA
I'm at 14.6. Sounds like holding off on updating would be good. I hope you find a solution and report it here.
Old Aug 1, 2021 | 07:41 PM
Curvfun's Avatar
Curvfun
I haven’t tried mine since updating to 14.7.1, but during a couple of past upgrades I had to delete my existing configuration / connection from the iPhone in settings, general, CarPlay and re-establish them again. Each time it solved the problem. Might be worth a try. Hope this helps.
Old Aug 1, 2021 | 08:53 PM
cutlass476's Avatar
cutlass476
Veteran: Navy
Even 14.6 screwed up my phone. My phone’s name was changed after the update to 14.6 to “iphone” from Max’s iPhone 12. Weird. This is just another reason to not update to 14.7.1.
Old Aug 1, 2021 | 09:29 PM
systemr's Avatar
systemr
worked fine for me, but i'm a 991.1 w/ aftermarket carplay kit
Old Aug 1, 2021 | 09:36 PM
BSO's Avatar
BSO
My ‘19 911 CarPlay is working under the new update.
No issues.
Old Aug 2, 2021 | 10:50 AM
boomlrd's Avatar
boomlrd
3rd Gear
Same problem, 2020 Macan Turbo and CarPlay works, but touchscreen within CarPlay is not working. I must do everything from the phone. I have tried deleting the phone and reconnecting, nothing changes. I have also tried both wired and BT, nothing. The touchscreen will allow only touching within the Waze app?! I can't go to menus, I can't change songs, or anything else. I am running latest 14.7.1 as well.
Old Aug 2, 2021 | 04:32 PM
Kelsey's Avatar
Kelsey
Hi All, Problem solved. I reset my network on the iPhone and tried CarPlay again and now it works. Thanks so much for all of your responses.
Old Aug 3, 2021 | 05:15 PM
Rich_Jenkins's Avatar
Rich_Jenkins
‘17 C2 base here. I just tried my iPhone w 14.7.1 and had no issues with CarPlay (did quick check of Waze, Music, and main menu.)
