Water dripping into front footwells
I’ve scoured the internet to no avail. Twice, I noticed a few drops of water dripping onto my right foot while cornering with the AC on. Not sure where the water comes from but other posts imply AC drains may be the culprit. I have not noticed “wet” carpets, and hope to fix this issue before that happens. Does anyone out there have a good “how to” clear the ac drains, or any other information on what my problem could be and how to fix it?
On another water drain note...
I know the cab has 4 rear water drains and I have checked them and periodically run weed eater trimmer line through them. There are also some from water drain lines that I do not know exactly where they are, but have run water down windshield and see the water drain from the bottom of the car. Since I can’t find the entrance, I have not “cleaned” these, but since they appear to be draining, I hope all is well.
if anyone knows/has pics of these drains, and how to clean them, I’d appreciate them.
again, thanks in advance!
tmarino (07-20-2021)
As for the water potentially dripping from the AC, I would suggest running the AC a while until you notice the dripping and then stop the car, get underneath the dash, and try to identify the source. Perhaps it's just a bit of benign condensation that's accumulating around the AC components inside the vehicle as a result of the cold air being produced in a warm/humid climate. Still worrisome but if you can visually identify where it's coming from, that would be a good start. Also, have you tried the weed trimmer line method for wherever you find the water draining from when you pour water down the windshield? That might lead to something.
tmarino (07-21-2021)
