194F Water Temp Display
The following 7 users liked this post by asellus:
AdamSanta85 (07-02-2021),
desmotesta (07-02-2021),
Rich_Jenkins (07-02-2021),
shammerman (07-04-2021),
Spaetzl (07-03-2021),
and 2 others liked this post.
I deselected water temp, because it means nothing in normal operation. You'll get a CEL if there is a coolant temperature problem. So you do not need it.
For my 4 displayed parameters, I chose Boost Pressure, Battery Voltage, Oils Temperature, and Oil Pressure.
polobai (07-02-2021)
What do you have up top then?
I had my car out on it's weekly run today; ya'll correct, the water temp was dead nuts on 194F. I removed the water temp from the MFD list and ended up with Oil Pressure, Oil Temperature, Battery Voltage and Compass. Thanks for the clarification.
Ever since we got married, my wife says I have CRS (*) syndrome.
* Can't remember...stuff.
yeah
jfischet (07-05-2021)
Its going to jump around between 175 and 220F depending upon when the fans and pump in the water cooling circuit turn on and off.
The oil temp is the smoothed temp of the engine.
I have seen this
I do have my eye on the 991.1 Center Radiator upgrade from Suncoast Porsche, Rennline sells them as well..
He likes boost
This thread is timely, I JUST noticed that my oil temp in my T in “Normal” mode settles around 223F, but in Sport it hovers around 196.
Is the car actually doing something different in Sport/+ to keep the oil cooler or is it just changing the report?
