Coolant warning message, overheat, but coolant level ok
Thanks for update. Keep us posted.
Just went for a spirited drive and had the same issue. Parked on the side, let it cool drove home no problem. Took to my shop that told me that's 99% an air bubble in the system after having add a third radiator. Get your system flushed.
Does anyone know if WG42 (replace coolant reservoir - factory recall campaign) is equivalent to this document : https://static.nhtsa.gov/odi/tsbs/20...19329-9999.pdf
I cannot understand if the coolant reservoir has quality issues and therefore is replaced by a new one with same part number OR if the coolant reservoir has an improved design with a different part number?
