Zunsport Radiator Mesh for 991.1 C2S
Wrtflyr (06-07-2021)
Where did you find those? I am looking on their website and can't find something to match.
Edited to add: Nevermind, I found them on Pelican/Amazon/etc. They look great! I take delivery next week of my '14 C2S. Might be the first purchase.
D.
D.
You might be looking at the item for the center (3rd radiator)
I ordered the kit that was for the left/right grills (6 pieces total, 3 on each side)
There is no bumper removal required. The grill pieces snap right in with 2 clips
I tried the radiator grill store mesh, but it wasn't an exact fit (I had issues with having the middle plastic vents snapping back due to the zip ties being in the way) and I returned them.
Apparently the best grill kits are from rennline (requires bumper removal) and zunsport (no removal required)
Those look much better from afar than up close. You can see from the outer corner of the lower panels that something about the fit isn't right. I recognize however that the function of these far outweighs the fitment.
I'm inclined to go with the Rennline version of these even though I know they will be a major pain in the rear to install by comparison.
If you are down on the ground looking up into the grills as in my pictures (I was lying on the floor almost) you'll see the bottom grill overlap the actual opening slightly, maybe I didn't bend them enough, but they looked a little off to me too.
The middle and upper pieces were a spot on fit tho
Still happier with these than the Radiator Grill Store ones...
