Jumpstarting 2015 911 GTS
Hi All,
I have a 2015 911 GTS. I am aware of the jump starting procedure as explained in the user manual.
My question is there any issue with jumpstarting using the car battery's negative pole as earth. I have a Duracell lithium ion jump starter with reverse polarity and reverse current feature. The reason I am asking is because the alligator cables thats comes with the Duracell product are short (11" for the positive and 8% for the negative) and hence for earth it won't reach the spot for earth as recommended in the user manual.
The Duracell product description can be found in the link: https://www.duracellpower.com/collec...n-jump-starter.
Also any recommendation for a portable jump starter?
Any views will be highly appreciated.
Regards,
Deb
Regards,
Deb
