.2 steering wheel problem
its adjust in/out ok but its in a LOW position and wont go up....it will go down about 1/2 " but not up at all...i cant see the gauges as the top of wheel blocks them and it is really akward.
ive fiddled with the switch, different pressures, different fingers, key is on, Ive reset the memory buttons..nothing works.
Am i doing something wrong,,,YES i read the manual and watched Youtube also..
goes back up same amount...say top of steering wheel in lowest position to top of steering wheel in highest position...how many inches about does it rise vertically......also is there a manual adjustment, im not seeing anything in the way of levers or such..
sounds like a limit switch got hoopajooped.
Jim
the seats and windows lose their calibrations when power is lost. so if you pull the battery, the one-touch up/down of the windows won't work, and I believe seat memory won't work, until you actuate the windows fully and actuate the seat all the way back respectively.
Jim ur the man! tried the seat all the way back and then to normal position, tried the up button and it worked..Thanx..
Jim981CS (05-15-2021)
Jim
MY new problem is I never use Navigation and its on and i cant shut her up...ive pushed every navbutton,driving me nuts..im not pushing the right button to shut her up
Jim
