AWE - Wind Difuser
AWE - Wind Difuser
Has anyone installed the AWE wind diffuser? I watched the video and later model 991.1's is about a ten minute install or less. On early model 991's (like mine) it requires door panel removal and I'm not quite ready to tackle this project. Anyone do this mod?
https://www.awe-tuning.com/awe-tunin...-wind-diffuser
Super easy, ton of ppl have done it
Here's a video for the .1
Bob in NY (05-10-2021)
Forgot to add that I found them to be a bit fragile.... be careful how much you tighten the screw. On the first set I installed, apparently I tightened the screw down too much... few hundred miles later I noticed I was missing one!
Thanks for the heads up. My big worry is taking off the door panels. I have all the proper tools but a bit nervous about it.
That sucks! Good info though, mine are slightly crooked, I think I will use double sided tape to hold them down. Additional info for anyone that wants to know, for my 2017 991.2, I did not need to remove the door panel.
