E Brake
E Brake
Anyone else think the e brake switch seems backwards? By that I mean push to engage, pull to release? Seems counterintuitive to me. It’s opposite my M5. It’s my first Porsche and it’s a strange thing to get used to.
GTSence (05-10-2021)
Yes.
Same on my 981S. I never did understand the human factors that went into the decision. I have a lifetime's use of standard, pull-up/thumb-button handbrakes ingrained on my lizard brain. Exactly why it makes sense to Porsche to do the brake this way escapes me. But perhaps there's a really good reason I'm missing. Be great if someone knew.
If you think of the handle as if it were a foot pedal from days of old, just substitute your hand for your foot. You would push your foot forward on the pedal to push the parking brake to the floor, thus you push the lever in to engage the brake. When you wanted to drive away, you reached down to the parking brake release lever and pulled it back.
If you think of it as a hand lever between the seats you will get it wrong. Shift your thinking back a few decades. You know, progress.
05ag987 (05-09-2021)
Pavegeno928 (05-09-2021)
I tried remembering by associating some logic to it (such as mentioned above) and would still get it wrong occasionally. One day I realized that I can engage it with my knee (push) but I need my hand to release (pull).
Yea... this is sort of like the A/C mode Off button - to turn A/C ON, you push the A/C OFF button and the light goes out. Seems backwards, a double negative. Maybe it's just me.
P991GTS (05-09-2021)
Kidding. That is as good an explanation as any I suppose lol. Thanks.
I remember 50s cars had a lever attached to a ratcheted, spring loaded rod you would pull and rotate to lock and rotate to unlock and let the spring expand, even back then it pull-engage, push-disengage.
Have you guys had an old American pickup? To release the parking brake, you pulled the release. And its funny because it's in the same spot. I think it makes perfect sense.
