anyone notice a buzzing from their sport chrono dial?
At certain speeds there's a resonant buzzing from my sport chrono dial. I can isolate the buzz because it goes away with pressure on the bezel. I took the center vent out to remove the clock and add foam tape but it looks like the buzz is the clock assembly itself. My car does have a factory exclusive manufactur red dial so I wonder if that's related as my cluster has a similar buzz .I don't know if the suppliers deliver instrumentation with the modification already installed or if it's done at Zuffenhausen.
If you're under factory warranty that's a warranty item. CPO you're on your own, so take it apart and find the loose screw. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Gripster (05-04-2021)
