eibach or techart springs??
How about go full coilover so you can tune in the right amount of low and ride quality.
If any of my PASM shocks go bad that's where I'm headed.
I agree... I'd also go full coil over if I was gonna mess with the suspension. I've used Eibach's many times, on different vehicles, in the past and after a while, the ride quality suffers immensely.
I may just be getting older (43), but it's just not that much fun anymore when the ride jars your teeth out. I still appreciate the look though, so I totally get it.
I run TechArts with the stock controller... I plan to get the DSC V3... and eventually will get B16s for the DSC V3....
The ride is fine, rather stock - does the job well... but a proper balanced suspension rather than a Frankenstein spring/shock setup would be leaps and bounds better.
From direct experience, you don't want progressive springs with PASM dampers. DSC helps, but does not solve, the problem—which is a car that rides a little nicer around town but porpoises when the springs get into their higher rates and PASM can't deal with it. It isn't a huge problem, but it isn't right.
Wish TPC Racing would develop/offer/recommend a spring and/or perch setup for the Carrera/T/S/GTS cars to go with its DSC. Have had my eye on the KW H.A.S., as I don't think I'll be able to live with the TechArt springs in the long run, but would rather buy from TPC and know it will work.
