Detailing question, how do you clean black wheels?
My recommendation so that you using your time efficiently. Remove wheels. Perform iron decon and assess finish clarity of current wheels. If not great, do 1 step polish. Ceramic coat the whole wheel with an appropriate higher temp approved coating. Let cure fully and drive the car. Will be light years easier to then maintain.
Use compressed air or leaf blower to blow out as much air as you can after washing. Immediately put car in garage. Check periodically for drips. Dry with mf towel or blow. Should be good to go.
Unless you have time to waste and like being frustrated anything else will be just that.
But still, I'm wary of taking of the wheels unless it's a tire change. The rims are in perfect condition, and this residue can be wiped off with baby wipes (just tried). So my plan going forward is to do as good a job as possible to clean the wheels and apply a Gyeon Wetcoat myself and then proceed to pulling it into the garage and wiping off any water that dripped down.
We'll see how it goes
I don't think a full ceramic coating will help more than doing the above to be honest. But time will tell...
This is what my detailer suggested when I did complete ceramic coating and ppf, however it was, translated to USD, over $100 for each wheel and the complete polish/ppf/coating was pretty expensive to begin with. Since I never cleaned a black wheel before, I told myself I'd try it first. Insert facepalm here.
https://thelastcoat.com/products/iro...-wheel-cleaner
I'm using this to iron off my GTS wheels and works quite nicely. I saw it from Remove Before Race guy advertising it and tried and surprised how well it cleans off.
watch this video and you will see how it turns brake dusts into purple. It's crazy.
I also highly recommend spraying Hyde’s Rust stopper right after each wheel and calliper is thoroughly cleaned and rinsed.
I’ve also realized an added benefit where this temporary eliminates the low speed brake squeal that’s always there for me. The squeal will eventually return once the brakes are dirty and the wheels are ready for another wash.
Spray directly on rotors after wash to prevent rust build up. Once it builds up on the rotors, it'll coat the inside of your barrels once you drive off.
Use this liberally after your wheels are dry inside the rims and it will repel the rust that may settle. I love this stuff especially!
I always blow my car and wheels dry which helps get a lot of the water out of crevices, etc.
I just finished cleaning up my black (powder coated by detailer's painter prior to delivery) winter wheel set for summer storage. These wheels were treated with ceramic by detailer when new (March 2019) and yes, that was pricey. I have tried multiple wheel treatments over the years. This time, I'm trying Dr. Beasley's spray wheel treatment. First time with it.
Black wheels are like a black car - rarely if ever perfect...
Think you will be happy with Dr Beasley. Mind you it will not necessarily keep brake dust off the wheels, but will make cleaning a lot easily. A quick spray with the hose will give you happy results.
Trying to upgrade pads on a base car is a whole other story...
Hydes helps a lot. I have also head great things on GSF.
My process is as follows (high level)
After car is washed and ready to be dried. I hit the wheels with Hydes ruststopper.
I then do a quick over the entire car with the leaf blower and get about 90% of the water off the car.
I then drive the car. This will remove and heat up the rotors enough for water to not sit on them.
I will park and usually dry with some sort of lubricant (bead maker is my current one)
I then go over the tires with Mineral spirits. Add your favorite tire shine after here.
While I am doing the tires, I check each rotor. 99% of the time I wont have anything dripping. But also check to make sure no rust is forming on the rotor as it will all come off dry once you take it out for the first spin.
If nothing I move on to drying spokes like normal and finishing up.
If there is Rusty water I take compressed air and blow the rotor and clean up.
Hope that helps.
Hope that helps.
Just a heads up. Per the recommendations on several threads, I used Dr Beasleys matte wheel cleaner on my satin black centerlocks. One of them is now showing the corrosion thing which I’m pretty upset about.
hopefully the other ones won’t follow.
I’ll probably replace the lock eventually and will onlymy use the car wash soap.
I wrote this up after looking into exactly this for my GTS. TLDR Shine Supply Clutch really makes them look great but isn't a long long term solution. But the only thing I tried (I have not tried Beasley's) which did anything remotely like what folks said it would do.
https://www.reddit.com/r/AutoDetaili...eels_restored/
My 2019 GTS came with satin black center locks and I have tried various solutions and there is nothing that works completely. However, I did try ceramic brake pads which worked great on my BMW but not on the 911. Finally, I had the wheels powder coated in gloss black and cleared and while the brake/iron dust is still there it doesn't show nearly as much and I don't feel like I have to clean the wheels each time I drive it. The surface is also smoother which means less of the dust sticks to the wheels - I learned this when I got new tires this week and they had a hard time getting the wheel weights to stick.
