If you really must.....use a pointy and tapered object (like a pick from a hook and pick set) to push into the pinched space. It will loosen. Then, use side or end cutting pliers to pinch them back. They should hold. I wouldn’t do it often on the same clamp...or even a third time.
Actually the hose will slide off without removing the clamp. Use a small screwdriver to pry underneath of the pinched clamp. You can push it back on with the old clamp in place.
I am also in the middle of installing a set of Soul Cats on my 2018 GTS. I ended up removing the ball / socket arms from each valve and then removing the 3-8mm nuts that hold the actuators onto the muffler. Easy to do, however there is a small retaining clip in the ball joint that has to be removed first. Not sure this is a better approach. I was just uncertain about having to replace the ear clamp on the hoses or damaging them pulling them off.
There seem to be no lubricant whatsoever on the ball / socket joint (5000 miles). I assume there is so much heat at that location that the factory just leaves them dry?
Just beginning investigating how to install the sport cats. Looks straight forward other than having a little bit of cramped hands.
how do you remove the vacuum line? Are those one time use clamps?
On my recent exhaust upgrade I just cut the old clamps off and replaced them with a standard hose clamp. Nothing special about these as it's only a vacuum line. If you notice most vacuum lines installed on todays car do not have any retention method.
Good Luck,
