Power socket anomoly
Just wanted to alert folks about something I found a while ago about the "auto-off" feature of the power sockets in the footwell and console.
They normally stay on for approx 30mins after leaving the car, however if you charge the battery via the commonly added tap into the battery you will find the sockets power up and stay so after the charger is removed.
So if you have your dashcam and radar detector plugged in to that very convenient footwell socket, be aware that a top up charge will turn into a continuous discharge when the charger is removed.
Not understanding, so are you saying that if you have say a CTEK charger connected to battery and charging, the footwell socket does not go off? Then when you remove the CTEK charger, the socket still does not go off and will drain the battery?
You understood well, that's exactly it.
Pretty sure you could unlock and lock the car and it would go back to normal.
Not sure what’s wrong with your car, but mine act normally. Ctek on for 2 months. Remove. Start car. Plug radar detector into same socket. Shuts off on it own when turning off car.
This is when you DON'T do anything but charge through an externally accessible battery port. Previous GTS and current GT3 the same.
