Does the the base 991.1 have a small plastic lip under the front spoiler? I have the painted front spoiler and PASM. I was looking under the front spoiler today and realized I don’t have one of those cheap plastic lips under the front. I swear I have seen them on other base models. Should I have one?
I have a 991.1 that used to have a thin black front lip, and changed it out for the "more aggressive" sport front lip as seen below. I believe all of them have a lip, looks like you even have the mounting holes/slots for one, but your bumper has the pointed corners that look painted and shaped similar to the original black plastic lip I had ... Below is what mine looks like
First pic is the sportier lip that the S and up models come with that I added on
This second pic (kind of hard to see) is the original black lip that really just had two points on either side that stuck out and is fairly flush with the bottom of the bumper through the middle. If you end up needing to get one, I recommend the one pictured above that I replaced it with, looks a lot better on the car
