FAL bolts 'weeping'?
The indy I took my 991.2 to for a brake fluid flush mentioned that the FAL bolts were 'weeping'. Nothing to worry about now but to keep an eye on it.
Has anyone witnessed this? I know these systems are hydraulic.
Worth bringing to the dealer to check out before my warranty is up?
I recently noticed a little oil/fluid around the bottom of my driver side front strut. Turned out to be a leaking driver side FAL hydraulic system which was replaced under warranty.
BondJ (08-16-2022)
Interesting. My 2017 had that done very early on, the banjos were weeping. Just needed a tightening. Can't remember if it was done under a TSB or not, but I remember it like the whole latch problem thing in that it was at least a known failure point.
