Tarett Brake Caliper Stud Kit - Length Question
Reached out to Tarett but did not get a response.
Will be switching over to the AP Racing 2 pc rotors and I believe they come with a spacer and longer caliper bolts.
I want to get the stud kit. According to their site the stock 991.2 uses the 85mm caliper bolt. Would the 95mm stud kit be the correct length to use with the AP Rotors?
Thank you!
Thank you!
Thank you!
Thank you!
