991.2 C4S Offset Question
Recently got a C4S and considering grabbing a pair of summer wheels. I believe my stock specs from Good To Know are: Front - 8.5 x 20 ET 49 / Rear - 11.5 x 20 ET 56.
The wheel manufacturer recommended the following instead to make a little more flush with body: Front - 8.5 x 20 ET 41 / Rear - 11.5 x 20 ET 50.
I don’t have any experience with changing offsets, so was just wondering what the impact of this change will be on handling at low and high speeds? Doesn’t seem like a lot (1.6cm wider at front, 1.2cm wider at rear if I understand these correctly), but not worth it to me to make slightly more flush if its going to noticeably change handling.
Thanks for the help!
